Activity › Forums › Adobe After Effects › Lens Flare Alpha
  • Lens Flare Alpha
    Posted by Shawn Davenport on May 19, 2006 at 3:50 pm
    How do i use a lens flare to respect the alpha channel when i render it as a tga. file. i believe i have the lens set up correctly on a solid with add. but when on top of an image that needs to be alpha the lens does not respect the alpa anymore as i render it as a tga. the project needs to be rendered as a tga as there is no other way around this.
    Chris Smith replied 20 years, 4 months ago 3 Members · 5 Replies
  • Chris Smith
    May 19, 2006 at 4:54 pm
    Are you setting the output settings to Millions of Colors+ (The plus means with alpha channel).
    Side note, it is common to not use an alpha with a lens flare but to just use the screen transfer mode instead.
    Chris Smith
    https://www.sugarfilmproduction.com
  • Mylenium
    May 19, 2006 at 5:14 pm
    Get an unmultiply filter such as Knoll Unmult from rRed Giant Software. It will create proper Alpha based on the luminance of the image.
    Mylenium
    [Pour Myl
  • Shawn Davenport
    May 20, 2006 at 4:40 pm
    thank you for the quick response…i have set it for the settings you suggested but no luck…i am using AE 6.5 i don’t see or understand what a transfer mode is? can you help me with that???
  • Shawn Davenport
    May 20, 2006 at 4:47 pm
    do you mean the mode effects such as add and screen? ok now i know what you are saying. i’ll try that…duhh^_^ i feel stupid!!!
  • Chris Smith
    June 2, 2006 at 4:56 am
    Yes, those. If you create a lens flare over black, just set the layer’s transfer mode to ‘screen’.
    Chris Smith
