Activity › Forums › Apple Final Cut Pro Legacy › Lens Correction Filter
Posted by David Lewis on November 3, 2006 at 3:31 pmanybody know a good filter to correct some lens vignetting? is there anything included with FCP that could corrrect it?
Scott Colthorp replied 19 years, 10 months ago 3 Members · 2 Replies -
Shane Ross
November 3, 2006 at 4:08 pmThere is a plugin to correct for a widescreen adaptor…but not one to create information that is in the black of the corners.
https://www.digitalfilmtools.com/55mm/
The image is blocked by the vignette, so it is not there. You can push in a little bit, like 5% and see if that helps.
Shane
Littlefrog Post
http://www.lfhd.net -
Scott Colthorp
November 3, 2006 at 7:05 pmI’ve tried a few – all seem to work pretty good:
1. Magic Bullet’s Misfire Vignette
2. Nattress G Vignette (lots of control)
3. Joe’s Filters: Soft Spot (Invert, Subtract mode, drop blur to ‘0’, and play with controls to liking)
4. FCP Soft edges filter
5. FCP Mask Shape + Mask Feather
6. FCP Four-point Garbage matte – LONG RENDERS (play with smooth, choke feather)That ought to fully disclose my obsession with the perfect vignette.
-s
