Activity › Forums › Adobe After Effects › lens blur – repeat edges?
  • lens blur – repeat edges?
    Posted by Jonkydong on April 2, 2007 at 12:32 am
    hiya folks,
    in ae7, has anyone found a workaround for repeating edge pixels on the lens blur, when using a depth layer? i find it really pesky that they didn’t include this on this blur.
    for reasons i won’t go into, i HAVE to use the builtin blur, no frischluft, no tinderbox, no nothin’.
    thanks a ton for any help
    j
    David Cabestany replied 13 years, 5 months ago 3 Members · 7 Replies
  • 7 Replies
  • Darby Edelen
    April 2, 2007 at 4:34 am
    [jonkydong] “has anyone found a workaround for repeating edge pixels on the lens blur, when using a depth layer?”
    Try putting a Fast Blur above the Lens Blur. Leave the Fast Blur at 0.0 Blurriness but enable the Repeat Edge Pixels and that should do it! Or at least it did in my limited testing =)
  • Darby Edelen
    April 2, 2007 at 4:37 am
    I just realized I did this without a depth layer… With the depth layer it didn’t seem to need repeating edges at all.
  • Jonkydong
    April 2, 2007 at 2:59 pm
    hey wuzel, thanks for the answer!
    this didn’t do the trick though. my depth layer is a simple ramp, on a solid the same size as the comp. the 0 to midgrey values are fine along the edges, but anything above becomes more and more blurred in from the edges of the frame.
    i’m also getting the same effect with compound blur. there must be an answer to this.
    anyone?
  • Jonkydong
    April 2, 2007 at 3:07 pm
    hmmmm….i just inverted my ramp, and switched the blur focal distance, and now there’s no problem. awesome. solved in a wonderfully random way; adobe!
    thanks again wuzel
  • David Cabestany
    April 4, 2013 at 4:14 pm
    I’m using a depth layer exported from Cinema 4D and Frischluft’s Depth of field, and still getting the blurred edges, any way to get rid of them?
  • Darby Edelen
    April 4, 2013 at 5:11 pm
    Can you post the offending images?
    Darby Edelen
  • David Cabestany
    April 4, 2013 at 6:50 pm
    Nah, don’t worry about it, it’s fixed now.
    If anything can I ask you ask you a somewhat related question? I’m using a lot of mattes, and I need them to be blurred to so the lumas match the main rgb image blurred by FL Depth of Field, however I can’t apply the plug in on an adjustment layer because it blurs my background layer too and starts causing the blurry edges. How do I turn my mattes out of focus? Do I need to apply the plug in to each matte separately?
