Activity Forums Adobe After Effects Lens Aperature effect for free
  • Lens Aperature effect for free
    Posted by Tl Westgate on January 3, 2008 at 2:29 pm
    In my quest to recreate a few of the Toaster transitions, I found Rick Gerard’s tutorial on creating a lens aperture here on Creative Cow.
    https://library.creativecow.net/articles/gerard_rick/Real_blades.php
    However, I really couldn’t follow along with the Illustrator part. In fact, the woman in our desktop publishing department couldn’t figure it out, either. Instead, I just saved the image of the blade shape and traced around it in Photoshop. Thus, the “blade.psd” file.
    Then, I followed along with the some of the tutorial about blade placement. I skipped the part about linking and all that stuff. I’m still learning AE and was a bit lost there. I just brute forced it and it works fine. I was toying with the idea of making the blade a new solid in AE and masking it out. But this is done and easy to use, so forget it.
    I added a sound effect from Andrew Kramer’s Sound Designer collection, but obviously I’m not redistributing that part. I highly recommend his products, found here: https://www.videocopilot.net/index.html
    You can find all sorts of camera sound effects online if you don’t want to purchase his excellent set of sfx, though.
    So, I put together this little “homage” to the Toaster camera lens transition. Feel free to render it out and use it for your projects.
    Lens aperture AE project
    Andreas Glatz replied 14 years, 1 month ago 2 Members · 1 Reply
  • Andreas Glatz
    July 27, 2012 at 2:31 pm
    thank you so much! exactly what i´ve needed right now 🙂
    regards, andi
