Activity › Forums › Adobe After Effects › Lengthening the presets
  • Lengthening the presets
    Posted by Bill Clotz on May 24, 2006 at 10:06 pm
    After Effects 7 comes with a lot of cool animated presets, but they are usually only animated for a couple seconds. Is there a quick and easy way to make them longer? Right now, I have to go onto each keyframe property and look how its changing, then I do some math to figure what values it should be over the new length. Needless to say, this takes a while!
    Jerry Witt replied 20 years, 4 months ago 2 Members · 1 Reply
  • Jerry Witt
    May 25, 2006 at 7:02 am
    Right after applying the preset, hit the “u” key to reveal the keyframes. select them all. Then scale the keys. You hold down a modifier key (can’t remember offhand — option or control?) and select the last key and drag it to the new last position.
