Activity › Forums › Adobe After Effects › Lengthening multiple comps and elements
  • Lengthening multiple comps and elements
    Posted by Rowan Bilkey on August 19, 2008 at 12:27 am
    ok, so I am putting together a football MVP style presentation where players receive votes for best player on a match by match basis. at the end of the season the player with the most votes is the MVP. so I set up a template for the backgrounds with reveals etc, and copied the template over and over for each game, adding different text for each game. my problem is, the client has just come back to me and told me they want to change the timings. I was wondering if there was any way I can script a change that will drag out all comps and elements but keep the timings in check.
    I hope I have described that clearly enough. any help will be appreciated
    Kevin Camp replied 18 years, 1 month ago 2 Members · 1 Reply
  • Kevin Camp
    August 19, 2008 at 4:49 pm
    crgreen has a script called selected comps changer that will change all selected comps to the settings that you specify (duration being one). he may have some other useful scripts for adjusting the length of the layers.
    ae enhancers is another place you might look for scripts.
    Kevin Camp
    Senior Designer
    KCPQ, KMYQ & KRCW
