Activity › Forums › Adobe After Effects › Lengthening layers in the middle of a comp and rippling time of everything after
  • Lengthening layers in the middle of a comp and rippling time of everything after
    Posted by Mike Welker on March 24, 2010 at 2:34 pm
    I’m relatively new to the AE world, and I’m hoping to get some insight into adjusting the length of layers in the middle of a comp and getting the remaining layers that fall after that to ripple down in time. I’m hoping that it’s easier than simply highlighting all the layers after the extended piece, and just dragging them down manually. Is it?
    I did some searching around but wasn’t able to find anything specific to this, but even a link to an existing post would be most helpful.
    I’m working in AE9, and as the title says, I have some elements in the middle that I need to extend in duration, and I want everything following to push ahead in time so those lengths remain the same, but the overall comp length will extend.
    Clear as mud?
    Many thanks!
    Mike Welker replied 16 years, 6 months ago 60,251 Members · 1 Reply
  • Mike Welker
    March 24, 2010 at 4:14 pm
    Many thanks, Dave. This is very much the same way it would be done in Motion. The issue with my particular comp is that there are quite a number of layers, and I also don’t know exactly how long I want to extend the layer(s) in the middle, so that means extending, followed by highlighting and moving, followed by extending, followed my more highlighting and moving, etc, etc.
    As an example, there’s an awesome single key command in Pro Tools -Shift+Option+Return- which will highlight every region on every track (every layer) that falls after the timeline cursor. I was hoping for something as luxurious in AE 🙂
    Mike
