Activity Forums Apple Final Cut Pro Legacy Lengthening a Slug
  • Lengthening a Slug
    Posted by Jason Mckee on March 6, 2009 at 11:02 pm
    I am looking for a way to place a TC Generator along an entire film without nesting the sequence and can’t seem to figured out how. I would love to just use the effect on a slug or something like that but I cant seem to make a slug longer than 2 minutes in length. In Avid you would just apply the effect to the track above. Is there even a way? Thanks in advance.
    Sara Fernandez replied 17 years, 1 month ago 4 Members · 3 Replies
  • Steve Eisen
    March 6, 2009 at 11:37 pm
    you can do this In Compressor and bypass the render.
    Steve Eisen
    Eisen Video Productions
    Board of Directors
    Chicago Final Cut Pro Users Group
  • Jason Levy
    March 7, 2009 at 2:05 am
    Put the slug on your timeline, edit it in the viewer and then manually enter the length to be 1:00:00:00 or whatever you’d like.
    You’ll then be able to pull the handle out as far as you need to. Works for me anyhow.
  • Sara Fernandez
    July 9, 2009 at 1:38 am
    I placed the slug in my timeline and edited the length in the box above and to the left of the timeline. It did not work for me — is there another place where the length might be controlled. BTW I/ noticed that other inserts like pictures were behaving in the same way. I went to my user preferences and extended the length for inserted pictures.
    Any suggestions? Thank you,
    Sara
