Activity Forums Compression Techniques Length of time for HD Compression
  • Length of time for HD Compression
    Posted by Thom Sullivan on January 22, 2009 at 5:42 pm
    Greetings, I have just begun to work with high definition projects in Final Cut Pro. I have just completed a 5 minute HD project., shot with a SONY Z1. There are two 2:30 sequences end-to-end. I have brought the sequence into Compression(set at DVD Best Quality 90 minutes) and started the process 20+ hours ago and it is still compressing with an estimated 12 hours until completion. I edit on a Powerbook, OSX with 2 GB Ram. I suspect it is lacking in power? Any insight is appreciated.
    Thank you.
    Thom Sullivan
    Comcast
    Thom Sullivan replied 17 years, 8 months ago 2 Members · 4 Replies
  • Daniel Low
    January 22, 2009 at 7:30 pm
    What are the specs of your Powerbook?
    Please post back saying what solved your problem. It could help others, and saying ‘thanks’ is free!
  • Thom Sullivan
    January 22, 2009 at 7:38 pm
    Daniel…I work with a Mac Power Book G4/2GRam/Mac OSX(10.4.6) with FCP 6.
    Thank you.
    Thom
  • Daniel Low
    January 22, 2009 at 8:00 pm
    You don’t give the speed of the processor which is kind of vital, but anyhow, your machine is going to run very very slowly with HD conversion but it should certainly have done that short job by now. Sounds like compressor has performed its usual ‘slow-down’ bug-trick.
    Quit the job and compressor restart the Mac and try it again
  • Thom Sullivan
    January 22, 2009 at 8:10 pm
    Daniel…# of CPU’s: 1; CPU Speed: 1.67GHz; Bus Speed: 167MHz
    I am 85% compressed so I’ll probably ride it.
    Thank you.
    Thom
