Activity Forums Adobe Encore DVD Length of stills in slideshow with long audio.
  • Length of stills in slideshow with long audio.
    Posted by Caston Sacmon on April 7, 2010 at 11:57 am
    Just a note for people who might encounter the same issue, because I had a huge problem and did not see a solution on here.
    I had a 1+ hour long audio track and 6 stills that I wanted to cross fade and fit to the length of the audio.
    When I went to build and burn I would get a “still length too long for slideshow” error. I only had 6 images in it and have not seen posts about this problem.
    Over and over, I tried everything. Finally, I just duplicated the stills in the slideshow, put the same stills in so there would be more still and the would be shorter.
    I put a cross fade on all and manual advance.
    It worked. I guess there is an issue with the length of stills in a slide show. I did not know this.
    Thought this might be helpful to have up here.
    Caston Sacmon replied 16 years, 5 months ago 1 Member · 0 Replies
  • 0 Replies
