Activity Forums Apple Final Cut Pro Legacy Length of a project Q
  • Length of a project Q
    Posted by Saya Hillman on May 18, 2005 at 8:20 pm
    In preperation for a 2 hour FCP project, I am wondering if I’ll be able to burn the whole thing using iDVD? Should I/how do I make the video quality settings as low possible to ensure being able to fit it all on one DVD (lower quality footage is ok for this project)?
    I don’t know if either FCP or iDVD will place a limit on length when exporting/burning?
    Jeff Carpenter replied 21 years, 3 months ago 2 Members · 1 Reply
  • Jeff Carpenter
    May 18, 2005 at 8:46 pm
    I’m fairly certain that iDVD5 will do 2 hours. (I think that version 4 only did 90 minutes.)
    I’ve never actually used iDVD for anything over an hour so I can’t promise you that, though. The one clue I’ve found is that the Apple web page says that iDVD5 will now allow you to burn to a dual-layer disc and put “4 hours of video” on it. Since 2 layers gives you 4 hours, I’m ASSUMING that a single layer will take 2.
    Is it going to be exactly two hours, though, or slightly shorter? Back when the limit used to be 60 minutes I found that you could only go up to 54 minutes or so since some space was taken up by menus and other DVD-code.
    There’s no problem with Final Cut. Just save your movie as a Quick Time movie and drag that into iDVD. (Check the iDVD preference settings first to make sure it will compress it the way you want before you drag it in.) I’m fairly certain that you can simply “Export” as a QT movie with “Make Self-Contained” UN-checked and that will work. (If it doesn’t, use the “Quick Time Exporter” to make a file. That’s not as good, though, so try the other way first.)
