Activity › Forums › Blackmagic Design › Legacy QT Playout
  • Legacy QT Playout
    Posted by Jacobo Rojsen on August 3, 2005 at 8:34 pm
    Why the “Enable Legacy QT Playback” option in BM system preferences is grayed out?
    Dual 2Ghz G5
    GeForce 6800 Ultra
    4.5 MB RAM
    Fresh Tiger Installation
    BM Dlink Xtreme
    Jacobo Rojsen
    Post Production Services, S.A.
    Mexico
    Kristian Lam replied 21 years, 1 month ago 4 Members · 3 Replies
  • Luke Maslen
    August 4, 2005 at 12:41 am
    Hi Jacobo,
    The “Enable Legacy QT Playback” option relied upon the use of Blackmagic codecs. In the DeckLink 5.0 drivers, we have largely eliminated the Blackmagic codecs and adopted the Apple uncompressed codecs as Apple have requested that we do this for simplicities sake. One of the side effects of this is that the “Enable Legacy QT Playback” option cannot be used. However, we’re examining options to see if we can make this work again so we haven’t removed it from the interface. If we can’t find a way to make it work, we will remove it but we haven’t given up yet 🙂
    Regards,
    Luke Maslen
    Blackmagic Design
  • Neil Sadwelkar
    August 8, 2005 at 11:54 am
    Does than mean that you can’t play back DV or 8-bit movies (or any codec other than AppleUC) in QT or BM deck control and see the output on the Broadscst monitor connected to the SDI out? Like you can with OSX 10.3.x and QT 6.5 and BM 4.8?
    Neil
  • Kristian Lam
    August 9, 2005 at 12:40 am
    Hi Neil,
    Blackmagic Deck Control will still work. It’s only playing out from the Quicktime application that is affected.
    Kristian Lam
    Blackmagic Design
