Activity › Forums › Live Events & Streaming › LED Wall Processor
  • LED Wall Processor
    Posted by Jason Horn on October 6, 2017 at 2:37 am
    Good evening,
    I have an LED wall that has a resolution of 3072X1408. It is currently being fed by 2 NovaPro wall processors from a Christie Spyder. It is using the DVI inputs on each, over 10BaseT for transport at 1536×1408 per side. Since this processor also has 3G SDI inputs, I wanted to run the copper to each, and eliminate the DVI extenders. However, I can’t get a signal to them. Will 3G recognize a format with over 1080 vertical lines? I understand that there are specific formats related to 3G SDI, but the data being passed seems well within the limits. Any ideas?
    Charles Tim replied 8 years, 7 months ago 3 Members · 4 Replies
  • Vince Becquiot
    October 6, 2017 at 3:50 am
    Hi Jason,
    SDI processing will almost certainly need a SMPTE standard signal and it’s very limited.
    That usually means 720 30/60P or 1080i / 1080P 30/60P only.
    After that we get into the 6G/12G for 2k/4k standards.
    Vince Becquiot
    Indigo Live | Kaptis Media
    San Francisco Bay Area
  • Jason Horn
    October 6, 2017 at 4:03 am
    Thanks Vince.
    What about running the 2 outputs at 1080p, and then scaling them with the NovaPros to the 1536×1408? Although I am sure the scaling power of the Spyder is much better than these units.
  • Jason Horn
    October 6, 2017 at 4:05 am
    Content is currently created at 3072×1408, and then compressed to 1080 for transport in our system.
  • Charles Tim
    March 1, 2018 at 10:15 am
    you can get the latest led video wall with Novastar Pro processor from here: novaledscreens
