Activity › Forums › Adobe After Effects › LED wall – odd aspect ratio
  • Walter Soyka
    October 25, 2013 at 10:04 pm
    [Kevin Camp] ” just drop the 960×360 comp into a 720p comp and then choose layer>transform>fit to comp and render that.”
    No need to fit it to the comp. It doesn’t have to fill the 1280×720 frame, it just has to fit within it. Staying 1:1 may be advantageous to avoid softening from scaling, given the low vertical resolution of the display.
    Basically, Paul, you are slicing and dicing your very wide comp to fit in a standard video size, and then the Pandora tech will un-dice and un-slice to put it back together as you originally intended. It’s like this:
    “ABCDEFGHIJKLMNOPQRSTUVWXYZ” is too long, so we rearrange it:
    “ABCDEF
    GHIJKL
    MNOPQR
    STUVWX
    YZ”
    And then just put it back together again on the other side.
    Walter Soyka
  • Ivan Myles
    October 28, 2013 at 9:31 pm
    Here’s the detail to support the other comments:
    i) Create the end video on a 5760×60 composition. Note that its center point is x=2880, y=30.
    ii) Create a 960×360 composition.
    iii) Drop the 5760×60 comp into the 960×360 composition six times and set the Position coordiates as follows:
    1: 2880, 30 (far left on top)
    2: 1920, 90
    3: 960, 150
    4: 0, 210
    5: -960, 270
    6: -1920, 330 (far right on bottom)
    iv) Export the 960×360 comp, possibly with Adobe Media Encoder depending on the codec.
    This approach allows you to focus on the final output in the 5760×60 composition without having to worry about splitting and synchronizing each slice.
Page 2 of 2
