Activity Forums Apple Final Cut Pro Legacy LED countdown clock effect?
  • LED countdown clock effect?
    Posted by Mike Raff on May 20, 2005 at 3:13 pm
    Apologies for the cross-post.
    Trying to come up with an effect for a client. He wants an LED-like timer counting down.
    The best I’ve come up with so far is the Time Code Generator filter in FCP cropped and keyed (and running backwards). It’s okay, except that I’d prefer an LED type font and I don’t think I can change the font in this font.
    Before I am reduced to shooting the display on my BetaSX deck, I thought I’d ask if anyone knew of an AE effect or FCP plug-in that will do what I need.
    TIA
    Mike Raff
    Richmond, VA
    Ben Zemanek replied 17 years, 5 months ago 4 Members · 5 Replies
  • Matt Sandström
    May 20, 2005 at 4:21 pm
    funny, i just helped this other guy out with the *exact* same thing.
    i have such a plugin in my free pack (see homepage). i’m working on a new version right now so let me know if there’s anything missing and i’ll try and add it. there are plenty of led display fonts out there. many of them free. just look around.
    /matt
    https://www.mattias.nu/
  • Arnie Schlissel
    May 20, 2005 at 4:23 pm
    Mattias Sandstrom has a free clock generator that should work well for this: https://mattias.nu/plugins/
    Arnie
    https://www.arniepix.com
  • Arnie Schlissel
    May 20, 2005 at 4:27 pm
    [Matt] “funny, i just helped this other guy out with the *exact* same thing.”
    Probably the other guy I referred to you the other day! BTW, I looooove your windblur cross! Now, if only I could adjust the angle of the blur…
    Arnie
  • Matt Sandström
    May 20, 2005 at 4:42 pm
    haha, thanks. unfortunately the wind blur cross only works in two directions due to fxscript limitations, but i’ve been looking into it. render times were really bad back in the 1.2/g3/192mb days but maybe today it’s not so bad anymore.
    /matt
  • Ben Zemanek
    April 16, 2009 at 12:04 am
    Hey guys,
    I had a problem when using the TMTS clock plugin with a certain font. The font is called Foundry Monoline and when I use it on the countdown, it flickers uncontrollably. It seems to work fine with all native FCP fonts. Is there something I can do fix this?
    Thanks very much,
    Ben
