Activity › Forums › Adobe After Effects › LED/Bright Lights transition effect?
  • Hector Vera
    July 25, 2023 at 4:24 pm
    Sadly I am unable to see this GIF file, may have been an error when you posted this question. But if you wish to use a LED/Bright Light for your After Effects, first you select two images you wish to transition and pass them to the timeline. Have the first image start from 0 seconds and then an image on top of it that starts around the 5 second mark. Then there you can probably find a stock footage online for Lens Flare that you can use to transition between the two clips. Here is a video I found that shows you the process to do the transitions: https://www.youtube.com/watch?v=Hw5x9xc58fc
    Hope it can help, there are many free Stock footage you can use for your transition! 🙂 Good luck!
