Activity Forums Audio Lectrosonics UCR100
  • Lectrosonics UCR100
    Posted by Gary Seith on July 26, 2010 at 8:55 pm
    We have been having problems with newly purchased Lectros.
    We bought the 100 series-
    Transmitters are Lectro LMa
    Receivers are UCR100
    They sound like crap coming into our mixer.
    We had to buy the XLR-to-mini cable because the UCR100 only has the mini out, but everything is EXTREMELY noisy.
    Anyone have any ideas why or what we can do to correct?
    Gary Seith replied 16 years, 1 month ago 5 Members · 5 Replies
  • Sam Mallery
    July 27, 2010 at 4:28 pm
    Did you go through the manual to make sure you have the gain structure correctly balanced between the transmitter/receiver/mixer?
    Have you ever used wireless mics before? If so, what system are you comparing the 100 series to sound wise?
    http://www.sam-mallery.com
  • Thaxter Clavemarlton
    July 27, 2010 at 8:07 pm
    [Gary Seith] “everything is EXTREMELY noisy.”
    Line level output into a Mic level input?
  • Ty Ford
    July 28, 2010 at 12:17 am
    Hello Gary and welcome to the Cow Audio Forum.
    If Sam and/or Thax’s good comments don’t resolve the issue, call Lectro. They give great phone.
    Regards,
    Ty Ford
    Want better production audio?: Ty Ford’s Audio Bootcamp Field Guide
    Watch Ty play guitar
  • Karl Winkler
    July 29, 2010 at 2:46 pm
    Gary,
    I’m sorry to hear about the trouble you are experiencing with your 100 Series setup. Most likely, the problem is that the LMa transmitters are not set to the 100 Series compatibility mode. The LMa is part of our 400 Series, and is capable of transmitting in any one of six (6) different modes. Changing it from one mode to the other is not terribly difficult, but does require some patience and the small screwdriver that came with the transmitters.
    First, check to see what mode they are in by powering on the units, and then counting the blinks of the two audio meter LEDs. After the initial blink, there should be a sequence of blinks and my guess is that there are four (indicating 400 mode).
    If that’s the case, here’s what you can do to change the mode to 100 mode.
    1. With the transmitter off, and the mini screwdriver, set the rotary switches to “C C” (for “change change”).
    2. Power on the unit briefly (like 1 second) then turn it off again quickly.
    3. Set the rotary switches to “1 1” for 100 mode. Power the unit on again briefly and quickly shut it off.
    4. Set the rotary switches to “0 0” (for “complete”) and then power the unit on again. Now, after the initial power blink, you should see the audio meter LEDs blink only once.
    5. Now, tune your transmitter back to the frequency you had selected by finding a clean channel on your receiver.
    6. Repeat for the 2nd transmitter.
    If this does not work, please give me a call at 505-994-9859 and we’ll figure out what’s going on.
    Sincerely,
    Karl Winkler
    Lectrosonics, Inc.
  • Gary Seith
    July 29, 2010 at 3:02 pm
    Karl-
    This was the issue.
    One of my colleagues spoke to someone at Lectro and they, much like yourself, were very helpful and walked him through the process.
    Thanks for your help.
