Activity › Forums › Boris FX Particle Illusion › Leaky Deflector
  • Leaky Deflector
    Posted by Toby Welles on November 19, 2009 at 2:21 am
    Hi, I’m having a problem with particles leaking through the deflector. should I create more points in the deflectors, make the the thickness greater or add another deflector in the same location. I want to keep the efficiency high, and the deflector has to be curved. I am trying to simulate a jet of particles flowing around in circular shape like an eddy by using a curved deflector and several forces to blow the particles along the path. I sure wish there were circular and or vortex force objects (Hint Hint)
    Thanks.
    Toby Welles, wowhouse.net
    Toby Welles replied 16 years, 10 months ago 2 Members · 2 Replies
  • Alan Lorence
    November 19, 2009 at 4:58 pm
    A couple of things to try:
    1) put another deflector close behind it, but don’t have the “corners” in the same place. (not a great solution)
    2) use only forces
    Unfortunately, you’re trying to do something that pI3 does not have tools to do very easily.
    Alan.
    http://www.wondertouch.com
  • Toby Welles
    November 19, 2009 at 6:03 pm
    I’ll just muscle through. Is this an area that you will be incorporating onto the next version perchance?
    I love to be able to do this sort of thing in PI rather than resort to a full 3D system which takes so much longer.
