Activity Forums Adobe After Effects Expressions Leaf falling expression (how do i get it to delay?)
  • Leaf falling expression (how do i get it to delay?)
    Posted by Simon Roberts on May 13, 2008 at 4:46 pm
    Hi
    i adapted one of Dan Ebberts tutorials to make a leaf fall from a tree. i’m really happy with it but i need it to start later than right at the beginning… and i’m having trouble doing that.
    I’ve posted the expressions below.
    i’m quite new to AE expressions… any help will probably save me hours of trying to struggle with it myself.
    Simon
    so this is what i have…
    there is a null layer and on the image of the leaf there are these expressions…
    The Point Effect (renamed ‘Life’)
    lmin = 1.5; //minimum particle life
    lmax = 3; //maximum particle life
    seed_random(1,true);
    life=random(lmin,lmax);
    birth=0;
    [birth,life]
    Postition
    gmin=20; //gravity
    gmax=70;
    w=20; //wind
    wdir=0; //wind direction (0 = from left)
    vmin=100; //minimum initial velocity
    vmax=300; //maximum initial velocity
    amin=30; //minimum launch angle from vertical
    amax=120; //maximum launch angle from vertical
    d=2; //drag coeffecient
    birth=effect(“life”).param(“Point”)[0];
    life=effect(“life”).param(“Point”)[1];
    origin=[position[0],position[1],position[2]];
    age=time-birth;
    s=random(vmin,vmax);//initial speed
    g=random(gmin,gmax);
    v_e=this_comp.layer(“Null 1”).position.velocity_at_time(birth); //emitter velocity
    a=degrees_to_radians(random(amin,amax)); //angle from vertical
    r=degrees_to_radians(random(360)) //rotation around y axis
    x=s*Math.sin(a)*Math.cos(r);
    y=-s*Math.cos(a);
    z=s*Math.sin(a)*Math.sin(r);
    v=[x,y,z]+v_e;
    new_speed=length(v);
    unit_v=normalize(v);
    if (d>0){
    delta_p=new_speed*(1-Math.exp(-d*age))/d;
    }else{
    delta_p=age*new_speed;
    delta_w=w*age;
    delta_g=g*age*age/2;
    wa=degrees_to_radians(wdir);
    origin + delta_p*unit_v + [delta_w*Math.cos(wa),0,delta_w*Math.sin(wa)] + [0,delta_g,0]
    Orientation
    rmax=0;
    rmin=-0;
    age=time-birth;
    if (life==0){
    [0,0,0]
    }else{
    seed_random(birth,true);
    init_orient=random([360,360,360]);
    final_orient=(init_orient);
    init_orient +(final_orient-init_orient)*(age/life)
    X Rotation
    rmax=360; //maximum rotation
    rmin=-360; //minimum rotation
    r=random(rmin,rmax);
    age=time-birth;
    if(life==0){
    0
    }else{
    r/life*age
    Y Rotation
    age=time-birth;
    if(life==0){
    0
    }else{
    r/life*age
    Z Rotation
    age=time-birth;
    if(life==0){
    0
    }else{
    r/life*age
    Simon Roberts replied 18 years, 3 months ago 2 Members · 2 Replies
  • Dan Ebberts
    May 13, 2008 at 8:06 pm
    I think all you need to do is change the birth variable in the point control expression and then add some code to each of the other expressions that checks to see if the current time is less than birth, in which case the expression does nothing.
    Here’s an example of a random birth expression for the point control:
    bmin = 0; // minimum birth time
    bmax = 4; // maximum birth time
    birth=random(bmin,bmax);
    [birth,life]
    And here’s the z rotation expression modification to get you started:
    Z Rotation
    if (time >= birth){ //***** this is new
    age=time-birth;
    if(life==0){
    0
    }else{
    r/life*age
    }else{ // **** this is new
    value // **** this is new
    } // **** this is new
    Dan
  • Simon Roberts
    May 13, 2008 at 10:59 pm
    ah…. amazing!
    thats perfect.
    thanks very much!
