Activity Forums Blackmagic Design LCD questions
  • LCD questions
    Posted by Rob Alexander on April 15, 2008 at 8:16 pm
    Hi, I’m planning to use an LCD display (Hazro HZ24 – good write ups, s-ips panel, seems credible alternative to ACD) connected HDMI-DVI from a multibridge pro to monitor HD 1080 50i/p. Given that it says its refresh rate is 60hz will there be any issues?
    Also will I be able to use huey/spyder to calibrate it properly – presumably by enabing it as a third display in the blackmagic control panel?
    Richard Cabeza replied 18 years ago 2 Members · 1 Reply
