Activity › Forums › Apple Final Cut Pro Legacy › LCD Monitor Settings
  • LCD Monitor Settings
    Posted by Ed Felker on January 19, 2006 at 1:28 pm
    Has anyone else had this problem. When the Apple Cinema display is set to 1344×840, playback the canvas jitters, and dropped frames are experienced on output through my AJA. But at 1200×800 all playback seems to be fine. I guess my question is: Can screen resolution cause the FCP to drop frames?
    The editor using this system has problems seeing the 1900×1200 setting.
    Here’s the system
    G5 Dual 2.5 w/ 6 GB RAM
    Lacie 500 GB FW800 Drive
    2nd internal ATA 200GB
    AJA IO
    Ed Felker – Post Production Editor
    WHDH- Boston- Creative Services
    G5 Dual2.5 GHz –
    Extra 300GB Internal ATA Drive
    LaCie 500GB FW800
    2 72GB SCSI Drives
    AJA IO
    FCP & After Effects
    Walter Biscardi replied 20 years, 8 months ago 2 Members · 1 Reply
  • Walter Biscardi
    January 19, 2006 at 1:54 pm
    [edfelker] “I guess my question is: Can screen resolution cause the FCP to drop frames?”
    Yep.
    You should be able to run the screen in full resolution though for the card / monitor. Check to make sure you’re running Millions of colors, not thousands.
    Walter Biscardi, Jr.
    Director, “The Rough Cut”
    https://www.theroughcutmovie.com
    Now Posting “Good Eats” in HD for the Food Network
