Activity Forums Apple Final Cut Pro Legacy LCD (lowest common denominator) for editing HDV sources
  • LCD (lowest common denominator) for editing HDV sources
    Posted by Bob Cole on September 16, 2006 at 10:30 am
    I’ve done the Search, read lots of prior posts which may answer this but I still have questions. Sorry if this is redundant but I would appreciate your expert opinions on HDV-HD-SD workflow.
    As I understand it, the consensus on this forum is to keep the show HD all the way through the edit even if the final output is SD, avoid editing HDV in FCP, and use DVCPro HD for editing your HDV-originated material. Using DVCPro HD from HDV may require as many as three devices for input: tape deck (e.g. HVR-M15U/M25U), HDV-to-SDI converter (AJA HD10AVA or Convergent Designs), and Kona 3.
    If I’m wrong or over-simplifying any of this, could you please correct me? ESPECIALLY if there’s a less-expensive alternative. I’m intrigued by, but still confused about the Blackmagic line-up; and I’ve seen some posts which concern me about Blackmagic’s customer support issues.
    The areas where I am confused, despite the many posts:
    1. VCRs: any significant advantage to the M25 over the M15? The LCD, timecode display, HDMI output which the M25 offers: worth the added $1k?
    2. the best bang-for-buck editing codec for HDV->HD->SD-on-DVD output.
    3. if the answer to #2 is still DVCPro HD: the sweet spot cost-effective RAID card/controller manufacturer/drive type/# of drives. (I know the answer depends on whether I use layers of video, how many layers, how much RT, etc. — I’m in the middle, use moderate compositing, don’t mind some rendering but prefer RT.)
    4. until I can outfit my new MacPro properly, is there any significant disadvantage to getting an M15/M25 and outputting my HDV signals as DV, and just using an external SATA drive on the MacPro? If, after a few months, I get the ideal HDV->DVCPro HD set-up outlined above, would I be able to re-master a show edited in DV?
    5. Extra Credit: Kona LHe vs. Kona 3 vs. the World of Blackmagic.
    Thanks for your help and patience with these perennials.
    — Bob C.
    Jim Martin replied 19 years, 11 months ago 4 Members · 6 Replies
  • Kevin Monahan
    September 16, 2006 at 3:52 pm
    Here’s your cheaper alternative: Edit HDV over FireWire, drop it off at a dub house for SD out. DONE.
    Kevin Monahan
    Take My FCP Master’s Workshop!
    fcpworld.com
    Pres. SF Cutters
  • Bob Cole
    September 16, 2006 at 6:53 pm
    [Kevin Monahan] “Edit HDV over FireWire”
    Thanks Kevin. That works, but my understanding from posts on this forum is that editing HDV in FCP is problematic.
  • Kevin Monahan
    September 17, 2006 at 1:42 am
    Rendering FX in HDV is the main problem because it takes more time than DV. That’s the main bitch anyway. It’s a pretty lame excuse if you ask me. If you don’t mind a small rant straight out of my book, here’s why I think it’s lame.
    You know, most editors are pretty dumb creatures when it comes to dealing with time managing renders. Admit it guys. Is this you?
    “NO, I MUST see my final quality and NOW”. (As you again press CMD + R…ZZZZZZZ)
    My reply would be, “No you don’t, you’re wasting time, move on to the next task ya lazy dog – render later when you are at lunch or yer done for the day”.
    If you compare an editor’s bone headed workflow (edit-render-edit-render, etc.) with how motion graphics pros work: with proxies, carefully previewing at low res, at lower frame rates, etc. you realize how stupid we editors can be. In fact, Apple gets it: they give us RT Extreme – but most people don’t know how to or maybe just do not want to maximize previews and merely check quality of an effect (by parking on an unrendered frame, going to QuickView, Opt + P etc.). The attitude is more like “Let’s render it first, then we’ll see how it really looks.” And you sit there and watch the little blue bar, sipping coffee.
    I’d say. “Hey Mr. TIME WASTER, you have work to do. Why are you rendering NOW instead of at lunch, break or overnight? The ONLY time that you should be rendering.”
    Editors and graphics guys work in two different ways, and to be honest, graphics guys work smarter in most cases when it comes to time managing renders and doing careful previews. We, as editors, must strive to be more like them. 😉
    Editing HDV is not a problem at all. You can edit HDV all day and all night and it should flow as easily as a DV project. Just do careful previews and never render until you walk away for a break or at the end of the evening.
    My 2 cents anyway.
    Kevin Monahan
    fcpworld.com
    Pres. SF Cutters
  • Bob Cole
    September 17, 2006 at 10:05 am
    [Kevin Monahan] “to be honest, graphics guys work smarter”
    Thanks. That’s not a rant, it’s very informative. Trish Meyers, After Effects expert, advocates the same approach, even to the point of scaling her originals no bigger than they need to be when animating stills.
    Your original advice was that the cheapest alternative is to edit HDV, & take it to a dub house for SD out.
    In what form would you take it to the dub house? And, if that isn’t usually an option for time reasons, what is the next-cheapest alternative, for in-house SD out? I’m thinking of buying the M15 or possibly the M25 deck anyway.
    Speaking of which, if anybody out there knows the ballistics of these decks I’d like to hear whether they are easy to control, cue up, etc.
  • Bob Flood
    September 18, 2006 at 2:42 pm
    hey bob
    we own the HDV camera and m10u. i edited one job in hdv native. I found it underwhelming at best.
    if you are going to be cutting only on a laptop or all by yourself, and you can finish yur show with enough time to render and export before fed ex then great, more power to you, go for it!
    however i work in the real world, where one or 2 producers have to see all the effects in real video on an NTSC monitor at any given time, and insist on making edits up to the very last second ie 5 minute to fedex.
    On my next job i digitized analog component through a Kona LH to dvcproHD and found it better. However i was not happy with the exporting of the footage for dvd as it got soft (my kona diod do an excellent job of downconverting in real time however)
    On the third job I digitized analog component through the kona LH to DVCPRO50 at 16×9. Best so far. accurate previews, quick export, efficient use of drive space. I have made this my workflow of choice.
    look at it this way, all the real time stuff is handled by the CPU. By capturing the stuff at the rez i want to output (I do not have a lot of call for HD masters etc) the card has done the “heavy lifting” and makes the RT previews a little faster.
    as for differences in the VTR’s? i think the extra mony is worth it for the M25, as it allows you to make HDV clones from a camera WITH MATCHING TIME CODE, something the m10u does not. And man the m10u is a lot slower than a real DVCAM Machine, like a dsr
    so if the M25u has a better transport, definitle go for it!
    hope this helps
    bee eph
  • Jim Martin
    September 18, 2006 at 3:33 pm
    Bob,
    what are you doing re: deck contol with the m10 when using the compoment analog outs?
    Jim
