Activity Forums Audio LCD for Pro Tools room
  • LCD for Pro Tools room
    Posted by Henry Gretzinger on April 17, 2006 at 7:37 pm
    Hello All-
    Any insight into LCD TVs for a high-end Pro Tools rig? I need something with near-zero latency (won’t fall out of lip-sync). Any ideas would be great!
    Henry
    Vidiots, NYC
    Aurora Support replied 20 years, 5 months ago 3 Members · 2 Replies
  • Don Greening
    April 18, 2006 at 3:44 am
    Last christmas I sat in on an audio sweetening session for the pilot of a new half hour TV series. The footage was shot in hi def 16:9 24P. The Pro Tools guy was using a Pioneer 50″ plasma. Nice.
    – Don
  • Aurora Support
    April 25, 2006 at 9:06 pm
    The only catch with high-end flat-panel TVs and monitors is that there is usually a significant delay through the input processing circuitry. You’ll want some to do some testing, to get the timeline offset dialed in, and if you’re using a DV converter, you’ll never get consistent offset while looping..
    The Syncheck is a great peice of gear for calibrating your offset, and a card like
    [Begin Shameless Plug 🙂 ]
    the Aurora Fuse-X is a great option for outputting video to your new display. Fuse-X plays any QuickTime compression format from within any QT-compliant application without interference or interaction with the application.
    – Mike Stroven
    Aurora Video Systems
