Activity Forums Adobe InDesign Layout Adjustment doesn’t work on text boxes!
  • Layout Adjustment doesn’t work on text boxes!
    Posted by Radek Robos on February 12, 2010 at 10:47 am
    I have to resize a multiple (60+) pages document from B5 to A5. I have tried the Layout Adjustment command, but it did not sized the content of the text boxes. Does anybody know a solution for resizing a whole leaflet including the text flow and the paragraph layout?
    I have tried both option for the Edit\preferences\General\when scaling command, but it did not worked…
    The document has to stay editable, so the „create a pdf, and resize this” is not an optionL
    Could it be a bug, as the original document was created in CS2, later opened modified and saved in CS3, and delivered to us? We haven’t got the original CS2 master, so I can’t compare it with the CS3 version document…
    Kelly Johnson replied 16 years, 6 months ago 2 Members · 1 Reply
  • Kelly Johnson
    February 14, 2010 at 3:57 pm
    Select all elements on a page, group, then resize. Your type will scale down so then you’ll have to ungroup all and adjust the style sheet accordingly.
