Activity Forums Adobe After Effects Expressions LayerSpace Transformations workshop
  • LayerSpace Transformations workshop
    Posted by Quejet on May 23, 2007 at 7:24 pm
    Layer Space Transformations are very interesting. Using 2d Effects to create 3d images is really something. Through shear luck I actually managed to use layer space transformations to make bumpmaps using the CC plastic effect. seen here:
    Are there any workshops that go over the space transformations in detail? I have some difficulty understanding them.
    Image Hosted by ImageShack.us
    Lord Scales replied 19 years, 4 months ago 2 Members · 5 Replies
  • Lord Scales
    May 23, 2007 at 9:32 pm
    Try http://www.motionscript.com, you will get them easily.
    But an easy (and maybe wrong) way to illustrate the Layer Space Transformations is:
    And the 2 axis in the image above can be given converting the layer’s Anchor Points to the Comp Space (camera affect) or to the World Space (camera doesn’t affect).
  • Quejet
    May 23, 2007 at 9:49 pm
    wuh HUH?
    … ooo k…
    anyway I’ve being to motion script and I’ve read through everything, its still not very clear because he just went over from comp and to comp, those are fairly strait forward, check adobe help on reference for layer space transformations, theres alot more to cover, and they’re not well documented either.
  • Lord Scales
    May 23, 2007 at 10:31 pm
    Oh, but basically the LayerSpace Transformations are these: toComp (), fromComp (), toWorld ()
    Thinks in the World Space as a 2D environment and think in Comp Space as a 2D environment affected by the camera.
    Sorry with my explanations are not good, I am terrible at writing tutorials and explanations.
  • Quejet
    May 23, 2007 at 11:04 pm
    but you can’t just think of them in 2d space because their 3d space transformations. They scope extends beyond just finding out where a point in 3d space lays on a the composition window Lord Scales. This is the information I’m after, workshops or something to overview these problems and to become more proficient in using them.
  • Lord Scales
    May 24, 2007 at 9:34 pm
    So I can’t help anymore…
