Activity Forums Adobe After Effects Layers starting between frames
  • Walter Soyka
    June 17, 2014 at 2:25 pm
    This can happen if you change the frame rate of a comp.
    Select the layers you want to move in time, position the current time indicator to the frame where you want them to start, and press the [ (open square bracket, next to the P) key. That’s the shortcut to move the in point of a layer to the current time.
    Walter Soyka
    @keenlive   |   RenderBreak [blog]   |   Profile [LinkedIn]
  • George Goodman
    June 17, 2014 at 2:26 pm
    Try using your left bracket key.
    “|_ (°_0) _|”
    Sincerely,
    George
    http://www.vimeo.com/georgegoodman
    http://www.linkedin.com/in/georgefranklingoodman
  • David Gruwier
    June 17, 2014 at 2:43 pm
    Ah! nice, I think that’d work.
    Next step is to figure out how to do that on a Danish keyboard, but I think that’s the solution. Thank you 🙂
