Activity › Forums › Adobe After Effects › Layers question from a newbie…
  • Layers question from a newbie…
    Posted by Ray Boone on September 30, 2009 at 1:40 am
    So…
    I am brand new to After Effects. Unfortunately, my company is running 6.0, and they won’t upgrade. My question is this:
    I’m trying to learn how to make the “3D Effect” with still photos. I know how to cut out the subject, clone the background, and save the background with layers intact. But when I try importing the file into After Effects, I get lost. It seems to want to merge all the layers together, which will negate the entire purpose for me.
    Any tips? Will 6.0 even allow this? Is there a workaround? Hope you guys can help.
    Todd Kopriva replied 17 years ago 2 Members · 3 Replies
  • Todd Kopriva
    September 30, 2009 at 2:43 am
    You didn’t say whether the file that you’re importing is a Photoshop (PSD) file, so I’m going to assume that it is.
    You need to import the file as a composition.
    To import a still image file as a composition, do this:
    1 Choose File > Import File.
    2 Choose one of the following from the Import As pop-up menu:
    • Composition – Cropped Layers
    • Composition
    There are quite a few things that can prevent importing as a composition. I can’t remember what all of the limitations were for 6.0, but I do remember that using CMYK or other non-RGB color models in Photoshop was one of them.
    Actually, this feature set hasn’t changed so much since After Effects 6.0 that reading this page and this page would be a bad idea. The second of those has a link to a script from Paul Tuersley that makes importing a PSD file as a 3D scene much easier. (I don’t know whether it works in After Effects 6.0.)
    putting the ‘T’ back in ‘RTFM’ : After Effects Help on the Web
    If a page of After Effects Help answers your question, please consider rating it. If you have a tip, technique, or link to share—or if there is something that you’d like to see added or improved—please leave a comment.
  • Ray Boone
    September 30, 2009 at 2:57 am
    Yes, I was trying a PSD file. Thanks. On another note, will a PDN (Paint.net) file work?
  • Todd Kopriva
    September 30, 2009 at 3:03 am
    Never heard of it.
