Activity › Forums › Adobe After Effects › Layers not rending in final output
Posted by Kingsley Asumadu on June 25, 2017 at 12:45 amHi Guys,
I’m having problem with rendering my final output from after effects composition.
The problem is every layer renders and are visible in the preview window but when I do a final render for final output two of the layers are not visible. Both of the layers are pre composed and one of them is a 3D layer.
I have included three images to illustrate the problem.Image 1 is before the project id rendered, image 2 is after the final output and the third image is the timeline with the two highlighted layers that do not render.
I appreciate every tip and thank you for your help in advance.
Kingsley.Walter Soyka replied 9 years, 2 months ago 2 Members · 11 Replies -
Kingsley Asumadu
June 26, 2017 at 2:46 amThanks for the reply Dave,
I’ve double checked to make sure all the layers are not guide layers, what I have noticed about the none rendered layers is that one of them is a 3D and when I check it off it renders with no problem, the other layer has an outer glow effect (layer style effect) applied to it.
I think this may be the issue, no? If it is what could cause those effects not to render?
thanks,kingsley.
Walter Soyka
June 26, 2017 at 2:33 pmPerhaps your view is set to something other than Active Camera? If you are previewing a different view, know that what you preview will not render the same way. Rendering always uses the Active Camera.
Image:
Walter Soyka
@keenlive | RenderBreak [blog] | Profile [LinkedIn] -
Kingsley Asumadu
June 26, 2017 at 11:14 pmYou right Dave, it’s the mixture of 3D and 2D, I definitely need more experience mixing those.
I’m creating the Star wars end credits crawl, and I need that 3d feel of the texts crawling into space and disappearing.
Do you know other ways I could create that without the 3D layer?
I have sorve the layer style issue partly using your advice, I basically created a shape layer and applied the drop shadow and enhanced it a bit, worked perfectly.
Thanks.Kingsley.
Kingsley Asumadu
June 26, 2017 at 11:25 pmThanks Walter,
Yeah I double checked to see if it was set to something other than ‘Active Camera View’ but it is actually on that setting.
I really don’t how to rectify the issue, I’m lost for leads.
I was asking Walter if there was other way I could create the ‘crawling text’ in star wars end credits scene without using 3D layer, your input on that will be much appreciated.
Thanks,Kingsley.
Walter Soyka
June 27, 2017 at 7:40 pmYou should not have to pre-render anything to get this to work. Can you post either the AEP itself (without footage is fine) or a screenshot of your complete Ae UI, showing both the viewer and as much of the timeline as you can fit?
Walter Soyka
Kingsley Asumadu
June 28, 2017 at 12:38 amThanks Dave,
This is brilliant idea, I’m currently out and can’t wait to try this out, I’ll post the outcome shortly.
Thanks a million.
Kingsley. -
Kingsley Asumadu
June 28, 2017 at 12:41 amSure thing Walter, I’m currently out and will that ASAP.
Thanks man. -
Kingsley Asumadu
June 28, 2017 at 6:20 pm -
Kingsley Asumadu
June 28, 2017 at 7:05 pmThanks Dave,
This is brilliant idea, it worked though i think I should work on the quality, the rendered quicklime is not crisp.
But thank you so much, now I know other ways to work in after effect.Thanks,
Kingsley.
