Activity Forums Adobe After Effects Layers move when I precompose
  • Layers move when I precompose
    Posted by Chrissy P. lópez on March 31, 2019 at 5:59 pm
    When I use a Texture in Alpha it gets transparent, and I read that the solution to that is pre-composing the layers. So, I do that and the problem that appears is the following:
    The layer moves from its position.
    Can someone tell me why?
    Thank you very much ♥
    Chrissy P. lópez replied 7 years, 5 months ago 2 Members · 4 Replies
  • Chrissy P. lópez
    March 31, 2019 at 6:23 pm
    “Paper TEXTURE” would be beneath a layer called “Paper”.
    The Paper texture is the texture of the layer Paper, and is with Alpha Matte.
    I say just straighten thing out in the pre comp and you’ll be fine.
    Do you I should move the layer in the pre-comp to its original position?
  • Chrissy P. lópez
    March 31, 2019 at 6:24 pm
    Do you mean I should move the Layer to its original position in the pre-comp?
  • Oleg Pirogov
    April 1, 2019 at 5:02 am
    Probably, cause Paper was parented to smth called Hand_L, which was not included to pre-comp, so Paper’s position switched to whatever. You would probably want to unparent it before pre-composing.
  • Chrissy P. lópez
    April 1, 2019 at 10:07 am
    Thank you!!!♥
