Activity Forums Adobe Illustrator Layers in layers palette don’t have objects available to select
  • Layers in layers palette don’t have objects available to select
    Posted by Riccardo Sinti on June 13, 2012 at 3:54 pm
    I frequently have this problem when I receive product layouts from clients.
    When I open the file in illustrator there are layers in the layers palette which contain multiple objects but I can’t twirl the layer open to directly select objects from the layers palette. If I create a new layer this problem remains.
    What causes this?
    Very frustrating and time consuming when I need to separate elements for use in after effects.
    Nicole Nel replied 14 years, 1 month ago 2 Members · 1 Reply
  • Nicole Nel
    July 24, 2012 at 6:27 pm
    If you open the panel drop down (arrow top right of panel) you’ll find “layer options” at the bottom of the menu. Click that and then uncheck “show layers only”.
    (This is in CS6)
