Activity › Forums › Adobe Photoshop › Layers IN AE W/ Cam movement
  • Layers IN AE W/ Cam movement
    Posted by Espnetboy3 on February 14, 2006 at 3:40 am
    Im trying to accomplish basically what andrew kramer showed in his compositing video tutorial about cam movement and DOF. I have my digi matte painting in photoshop. Its a flat tiff, and I want to create a foreground middleground and background cutting them out and layering them in 3d space in AE giving it a more realistic feel and look. The problem is that I use the lasso tool to cut my layers out but they dont seem to match up when I bring them into a new comp and or another photoshop document. My digimatte is some rediculous size because i did not realize this when i was working on it and didnt plan to add cam movement. So I made a new one and made the size 720×480 and now when i drag my layers I cut with the lasso tool and try to put them together like a puzzle to make the same pic so when i bring it to AE i can create this depth, they arent lining up and even when i resize them its all off. ANY HELP as to how to create this effect would be fantastic. Im kind of in a rush I hope you understand what I am trying to accomplish. Thanks
    Jayse replied 20 years, 7 months ago 3 Members · 2 Replies
  • Renato
    February 14, 2006 at 4:11 am
    is it possible to see a screenshot of the image you are trying to use? might make it easier to point out what the problem is. Either that or I hope someone else brings you a solution..
    good luck
    renato
  • Jayse
    March 3, 2006 at 2:49 am
    typically what I’ll do is make the PS file at least twice as big as I need. Keep all the layers in PS – save – import as composition in AE.
    Then turn all layers 3d except the background.
    Then change the z-depth of each – forwards and back
    Then change the scale of each to compenate for the z-depth
    Then animate your cam…
    I think maybe you were skipping the scaling step so they didn’t align anymore.
    Hope that helps!
    // jayse
    Ultimate After Effects Video Training CDs
    Free Photoshop CS Video Tutorials
