Activity Forums Adobe After Effects Layers get interved/reversed when add 3D layer
  • Richard Garabedain
    April 26, 2017 at 10:16 pm
    its true if you move the postiion it will solve but it shouldnt be doing that…try making them 3d and then adding a camera
  • Roei Tzoref
    April 26, 2017 at 11:07 pm
    [Dave LaRonde] “After Effects can’t show you all of them, so it uses the layer order — you see the top layer in the composition.”
    Yes it can. there is a layer order and it should be maintained. the preset he is using can change the perspective, but the layer order should be the same as in 2D. there is some sort of bug here. Op try this:
    1. when you create your camera choose a 50 mm camera preset and see if that’s works
    2. first set your layers to 3D then add a camera. no null . see if that works.
    if it’s still happening this way, try to create a new composition and copy the layers there and see. still no dice?, close Ae and upon launch reset your preferences: Reset After Effects Preferences
    Roei Tzoref
    After Effects Artist & Instructor
    ♫ Ae Blues Tutorials
  • Roei Tzoref
    April 27, 2017 at 4:11 pm
    [Dave LaRonde] “This is absolutely normal behavior in AE; given 2 layers with equal z-value, the upper layer in the comp gets precedence. This is the situation the OP faces. It’s not brain surgery.”
    the layer on top is the one you see, but this is NOT the situation Op faces. Op was facing something different: as soon as he clicked the 3D switch, the layers reversed their order and the layer at the top of the stack was the bottom in appearance and vise versa. he fixed it by trashing the preferences apparently: https://forums.adobe.com/message/9479841#9479841
    Roei Tzoref
