Activity Forums Adobe InDesign Layers from an Illustrator file
  • Layers from an Illustrator file
    Posted by Jeff Cochran on August 3, 2011 at 8:10 pm
    Hello,
    I’m importing individual layers from an illusrator file using the the “Show Import Options” function in InDesign. I currently have 20 layers from the same .ai file imported as separated graphics. I recently opened the Illustrator file and made some changes.
    Now, when I update the graphics in InDesign, instead of updating the graphic with only the layer I originally imported, it updates each file with every layer in the illustrator file.
    Is there a way for me to have InDesign update just the layer?
    Thanks in advance for the help.
    Jeff
    Dwayne Smith replied 15 years, 1 month ago 2 Members · 1 Reply
  • Dwayne Smith
    August 8, 2011 at 2:52 am
    G’day Jeff,
    Yep, InDesign is a bit of a pain in that way. If you add, delete, or rename layers in your source file InDesign doesn’t know how to handle your original Object Layer Options — so it imports all visible layers. If you just edit content on the various layers, you’re fine — but make edits to the layers themselves and you got yourself a world or arrgh.
    d.
