Activity Forums Adobe After Effects Layers Chopped Off after import from Ai to AE
  • Layers Chopped Off after import from Ai to AE
    Posted by Justin Falck on August 26, 2011 at 4:14 pm
    I am having an issue where my layers are getting chopped off. I am running Ai and AE in CS5. I brought the layers into my AE composition and it worked perfectly fine at first. They after spending countless hours on my motion graphic I decided that I wanted to add more detail to my artwork. After doing this several of my layers got chopped off when I reloaded the layers. This is extremely frustrating and I am scared I will have to start ALL over again. Any ideas?
    Cathy Hamilton replied 12 years, 10 months ago 3 Members · 3 Replies
  • Angie Taylor
    August 27, 2011 at 8:05 am
    In Illustrator you can adjust the Artboard size to make sure it accommodates all of the image before importing into AE. Select the Artboard tool, click on the Artboard and either resize it manually to fit around the image, or enter numeric values.
    To avoid this happening in the future you can use the Preset artboard sizes as templates when designing your artwork.
    Hope this helps.
    cheers,
    Angie
    Angie Taylor animation & illustration for television, film, web and devices
    https://www.angietaylor.co.uk
    Twitter: theangietaylor
    Linkedin: theangietaylor
    https://www.facebook.com/pages/Angie-Taylor/118378194869002
  • Justin Falck
    August 29, 2011 at 5:55 pm
    No I dont think it is either of these things. All of the artwork is inside the document as well as the artboard (which I a only using one of). I even went so far as to create a completely new document with just the one layer that is getting cut off in it and this did not help at all either.. UGH sooo frustrating. Any other advice you can think of?
  • Cathy Hamilton
    November 14, 2013 at 10:38 pm
    I had that problem, too. Searched high and low and tried various supposed fixes. None worked until I stumbled upon the suggestion to add a stroke around the object that is truncating. It worked. It came into After Effects whole again. Hope this helps someone. (working in CS5, btw)
