Activity › Forums › Adobe After Effects › Layers and precomposing
  • Layers and precomposing
    Posted by Craig Clark on November 12, 2014 at 4:30 am
    Ok, I just want to make sure I’m correct in what I’ve discovered.
    1. You cannot paste a layer between two compositions in After Effects.
    2. Once you create a composition with a quick time movie then place that composition in another composition you cannot move that composition in the timeline and you cannot resize the movie.
    …ok I lied I found I could at least resize, but still can’t move in timeline unless I enable time-remapping.
    Why does this layer require time remapping but the others don’t. They are even more complex.
    Craig Clark replied 11 years, 10 months ago 2 Members · 2 Replies
  • Tudor “ted” jelescu
    November 12, 2014 at 7:39 am
    I tried to replicate your issue and I had no problems moving the precomp in the main comp on the timeline. From your stills it looks like you are stretching the precomp – is that what you are referring to when you say moving?
    Tudor “Ted” Jelescu
    Senior VFX Artist
  • Craig Clark
    November 12, 2014 at 11:45 am
    I did stretch it, but not that I care about that. I also have a mask on the video. I don’t think that matters though. It seems like, the embedded composition settings (0:00-1.17 sec) are also the main composition settings when it’s embedded and I can’t change them unless I check time remapping. I also previously used layer monkey to add lyrics (to main) then I removed them. I wonder if it changed some setting in the main comp.
