Activity › Forums › Boris FX Particle Illusion › Layers
Layers
Posted by Cenk Yartan on April 5, 2007 at 7:28 amWell, This is new but nothings impossible.I want an emitter which gets tranparency from layer 1 and gets color form layer 2.Is this possible?
Thanx.
Alan Lorence replied 19 years, 5 months ago 2 Members · 7 Replies -
Alan Lorence
April 5, 2007 at 12:39 pmNo, not directly. Here’s what you can do though: using another app, combine your 2 layers of footage into 1 layer of footage, using the color channels from one and the alpha channel from another.
Then use this new single footage layer in particleIllusion, with “get color from layer” and “get transparency from layer” checked. You can turn off the bg footage when rendering.
I think that will work.
Alan.
Cenk Yartan
April 5, 2007 at 2:28 pmwell, it didn’t work out well.I combined the two videos and i add transparency but plusion doesn’t recognizes it.
Alan Lorence
April 5, 2007 at 2:33 pmDid you save it as PNG or TGA? If you used a different format, I’d suggest one of those two.
Alan.
Cenk Yartan
April 5, 2007 at 3:04 pmOwww Thats why Elvis Deane saved his video like that.Thanks ill try that.
Cenk Yartan
April 5, 2007 at 3:19 pmDo we have to save it with only png format.Cant we save it with tiff or targa?Cuz’ Adobe Premiere doesn’t support png.OR maybe you can tell me a PNG Plug-in(if it exists) For Premiere.!?.
Alan Lorence
April 5, 2007 at 3:35 pmI said “TGA or PNG” didn’t I? 😉
I don’t usually use TIFF because there are too many different “flavors”, and particleIllusion doesn’t support all of them.
Alan.
