Activity › Forums › Adobe Photoshop › layers
layers
Posted by Ruben Rodriguez on June 14, 2008 at 10:43 pmI’m new to PS. The question is how do you save a color to a layer so that if and when you access the layer, the same color automatically set.
Ruben Rodriguez replied 18 years, 3 months ago 3 Members · 3 Replies -
Jeff Kelley
June 20, 2008 at 9:31 pmI don’t believe you can, but once a color is used, you can just sample it with the eye dropper to get it back.
Kim Segel
June 30, 2008 at 6:24 amAlthough you can’t make it automatically pop up when you switch to that layer – you can save custom colors to your Swatches tab.
First, make sure the Swatches tab is open (under Window)
Set the custom color you want as the foreground color
Float the cursor over the blank bottom area in the Swatches tab area
When you get the paintbucket, click, give your color a meaningful name and click OK
You can even save and load whole swatch setups – which is great when you’re working on a client website with a very specific color palate.
A computer once beat me at chess, but it was no match for me at kick boxing.
–Emo Philips
