Activity Forums Zaxwerks layermap video to a plane issue
  • layermap video to a plane issue
    Posted by Julian Sixx on June 4, 2006 at 4:40 pm
    Hi
    I did the 3d ribbon text effect with invigorator and it works.
    [Jon Okerstrom] “you could create a simple rectangular plane and layermap the movie of the person to the front face of the plane.”
    It works to layermap the movie of the person to the plane but it’s rather impossible to give the plane the right size, so that the person will look like in the original footage!Any tricks ?The person is distorted,aspect ratio is incorrect!Is there a rule when you layermap movies?
    Julian Sixx replied 20 years, 3 months ago 2 Members · 3 Replies
  • Julian Sixx
    June 4, 2006 at 4:56 pm
    one more question
    I’ve got two objects,a cylinder+a plane in the same scene.
    Transparency map for the cylinder is an animated text layer=>wraps around the cylinder.
    In the middle of the cylinder is a plane(video as a layermap).
    My question:How can i drop shadows from the cylinder to the plane?In other words, i want to drop the shadow of the text(cylinder) on the Video.
  • Serge Hamad
    June 4, 2006 at 7:20 pm
    Create a plane at the same aspect ratio then your movie. For example if your movie is, 720 X 480, create a plane that is 720 X 480.
    Although you could drop a shadow from your whole cylinder, unfortunately you won’t be able to drop a shadow representing your letters only as the drop shadow function in Invigorator doesn’t recognize the alpha channel yet.
    Send me a still from your clip and I will see what I can do for you. (serge_01 at msn dot com)
    Salut.
    Serge
    “InvigoMany” Available here:
    https://www.nyc-visual.com
  • Julian Sixx
    June 4, 2006 at 8:13 pm
    Hi
    [serge] “Create a plane at the same aspect ratio then your movie. For example if your movie is, 720 X 480, create a plane that is 720 X 480”
    Sometimes it can be that easy 🙂
    Thank you
