Activity Forums Maxon Cinema 4D Layered Texture – Bitmap Transparency / Stacking
  • Layered Texture – Bitmap Transparency / Stacking
    Posted by Aaron Pozzer on April 22, 2015 at 9:29 pm
    so, for the life of me I cant figure out what should be an absolute basic and easy function: how to add an image texture that has transparency. im not talking about a material alpha channel. id like to be able to stack image, via the layered shader.
    i have my diffuse color set. id like to add an image ontop that is mostly transparent. i’ve tried a png, a tif, and a psd. they all come in with the “transparent grid” baked in (the grid you see in PS when you have nothing). i’ve tried using a layered shader and setting 1 layer to be a layer mask. nothing is working.
    is cinema unable to apply an alpha to a bitmap? certainly seems that way to me at the moment.
    Aaron Pozzer replied 11 years, 5 months ago 2 Members · 2 Replies
  • Brian Jones
    April 23, 2015 at 12:52 am
    can you post the scene (or a simple file which illustrates it) – it’s working here – in a Layer shader a base color and an image above with transparent pixels… are you doing something different?
  • Aaron Pozzer
    April 23, 2015 at 11:48 am
    it seems to have gone away this morning. i dunno… it definitely wasnt working yesterday, because ya, thats exactly what i was doing Brian. closed cinema when i left, opened this morning and now its working. i guess the old ‘have you tried turning it off and on again’ holds true in this case.
    EDIT:
    so after a few more min i realized the problem seems to somehow be linked to the fact that i was painting in BP. that is probably where the transparency grid was coming from. i thought perhaps it was because the texture was still open in BP, so i saved it, closed all textures, but that didnt quite fix the problem. reverted the scene, loaded my newly saved texture (saved as a psd), applied it to the layer stack in the shader and it worked.
    so i dont know if theres a proper way to work with BP for texturing, but if there is, apparently i was doing it, and i still dont quite know what i was doing wrong, but at least i know if i run into this error again that i know how to solve it enough to keep working.
