Activity Forums Apple Final Cut Pro Legacy Layered Photoshop Import Error
  • Layered Photoshop Import Error
    Posted by Ted Kusio on April 21, 2005 at 7:20 pm
    Sometimes when I import a Photoshop file into FCP I get a great sequence that I can edit and play with layers and call my own as an actual FCP4.5 sequence.
    OTHER TIMES I import a file, and although I can use it in my main timeline, I can’t edit it as a sequence. I get an error stating that I don;t have the right codec, and then an “Out of memory” error.
    What am I missing (other than my diginity)?
    –ted
    Ted Kusio replied 21 years, 5 months ago 2 Members · 5 Replies
  • Ted Kusio
    April 21, 2005 at 7:27 pm
    PS The image is RGB, not CMYK, and there aren’t any masks, layer effects nor paths.
  • Troy E. parker
    April 21, 2005 at 9:06 pm
    Typically this is caused by having an empty layer in the psd file.
    Check that first, if not on to the next step!
    Regards,
    Troy
  • Ted Kusio
    April 22, 2005 at 4:23 am
    No empty layers…
  • Troy E. parker
    April 22, 2005 at 1:16 pm
    are you using a x-large resolution file? I got a similar message when I attempted to import a very large file for a pan-scan.
    T
  • Ted Kusio
    April 22, 2005 at 9:30 pm
    No, I don’t think it’s too big (I get that error sometimes too when a file IS huge):
    445 x 500 pixels
    72 dpi
    7 layers
    About 2.3MB
