Activity Forums Boris FX Layered Brushes Imagens
  • Layered Brushes Imagens
    Posted by Sergio Anaya on June 26, 2008 at 7:56 pm
    That I did was to create a different imagenes, an imagen by layer, in my photo editor, which is Paint shop pro X, it has the ability to save the file as Photoshop file, then I took that file to make with the bruch optiion a drag crossing the screen expecting that my different layer aprearce one by one, but that got was only the last layer from the file, the one below, I change the layer order and then tryed it again in BR, getting the same result!!!.
    How can I make this kind of effect?? with the brush I want to paint different imagenes one by one.
    Comments are welcome.
    Sergio Anaya replied 18 years, 2 months ago 2 Members · 2 Replies
  • Peter Mcauley
    June 26, 2008 at 8:15 pm
    Hi Sergio,
    The paint system only accepts layered .psd files that were generated by Adobe Photoshop. That’s the problem that you are encountering. Just because you saved from Paint Shop Pro as a .psd file does not mean that these files will release their layers to RED – it must come from Photoshop.
    Hope this helps.
    Peter.
  • Sergio Anaya
    June 26, 2008 at 9:49 pm
    ok, thanks for answer!
    Regards
    LIQUID 6.1
    3.2 Gb processor
    1 Gb DDR
    128 MB CARD
