Activity Forums Adobe After Effects Expressions Layer visibility expression no longer working
  • Layer visibility expression no longer working
    Posted by David Cabestany on May 7, 2021 at 5:17 pm
    I have used this expression hundreds of times:
    x=thisComp.layer(“name of the layer”).active;
    if
    (x==1)
    {0}
    else
    {0}
    It’s supposed to lower the opacity of the layer it’s being applied to if another layer is active and raise it to 100 if the other layer is turned off. Basically, a layer switcher bypassing a checkbox control.
    Today it stopped working, no error or anything it just does nothing.
    Any ideas?
    Dan Ebberts replied 5 years, 4 months ago 2 Members · 4 Replies
  • Dan Ebberts
    May 7, 2021 at 5:36 pm
    It should work if you change the first {0} to {100}.
  • David Cabestany
    May 13, 2021 at 9:41 pm
    Hi Dan, somehow I missed your reply. I thought nobody had answered.
    Yes, sorry, I posted the expression with a typo. Sorry about that.
    This is the expression that used to work and doesn’t anymore:
    p=thisComp.layer(“name of the layer”).active;
    if
    (p==1)
    {0}
    else
    {100};
    If I invert the values it doesn’t work either, but it does not return an error.
    Thanks.
  • Dan Ebberts
    May 14, 2021 at 3:28 am
    It works for me as long as I replace your curly quotes with straight quotes.
  • Dan Ebberts
    May 14, 2021 at 3:35 am
    I think I’d do it this way:
    thisComp.layer("name of the layer").active ? 0 : 100
