Activity › Forums › Adobe After Effects Expressions › Layer tagger with precomp support
  • Layer tagger with precomp support
    Posted by Dieter Mueller on November 21, 2008 at 5:59 pm
    I have a pretty big composition with many precomps. It is something like a configurator. Now I need a way to turn on/off several layers within my comp and precomps because I don’t always want to open each precomp and select/deselect the layers. There are a tons of it.
    Is there a possibility or a script (something like the Layer Tagger) which supports precomps?
    thanks
    Dieter Mueller replied 17 years, 10 months ago 2 Members · 2 Replies
  • Eric Sanderson
    November 21, 2008 at 7:29 pm
    Im sure there is but i use something that might be able to help you…look up “Zorro-The Layer Tagger”, its free and great for stuff like that.
  • Dieter Mueller
    November 21, 2008 at 11:32 pm
    I tried that but it doesn’t suppoert precomps. I still have to open every single precomp manually if I use that script. It doesn’t help much if you have tons of precomps.
