Layer Styles vs Effects & Presets
Hello,
A layerstyle (drop shadow) on a pin drop on a map , (when pin is duplicated 40+ times) takes unnecessarily long to render.
Would it be faster to use Effects & Presets> Drop Shadow ?
How are these calculated ?
Also, “Trim Paths”. which is nested like a layerstyle, would this be similarly render intensive VS just drawing a path and applying Effects & Presets > Stroke ?
Regards,
Kavinsky
