Activity › Forums › Adobe After Effects › Layer Styles outlines on the inside makes round edges
  • Layer Styles outlines on the inside makes round edges
    Posted by Stefan Koler on April 6, 2012 at 7:34 am
    When I make outline layer styles and position them on the insde, some inner corners get rounded. When I position my outline on the outside all corners show up as they should (no round corners).
    (EDIT: Thats wrong of course the inner corners are okay but the outside ocrners get rouded.)
    Unfortunately positioning them on the outside makes my mask bigger, which is bad because I have to be very exact in this case (I am rebuilding elements from a illustrator logo in after effects, so that I can easly animate it. I copied the shapes of every single element on a seperate solid. So, now I have a mask in the exact shape of each element. Unfortunately I didn’t realized that when I copied the shape from illustrator it copied the full shape including the outline stroke that is surrounding each element. That’S the reason why I have to put my ae-outline on the inside of my mask). Any ideas?
    Erik Waluska replied 14 years, 5 months ago 2 Members · 1 Reply
  • Erik Waluska
    April 6, 2012 at 5:02 pm
    I don’t understand. You said positioning the stroke on the inside works, right? What else are you trying to accomplish? And I totally agree with Dave that it would be easier to just import the AI file as a composition with all of the elements separated into layers.
