Activity Forums Adobe After Effects Expressions layer spins around Z axis
  • layer spins around Z axis
    Posted by Sebastian Martinez on November 5, 2007 at 12:10 pm
    hi there,
    maybe i’m doing something wrong in a very simple way – this is my problem:
    my camera flies over a text layer which is on auto-orient. but when the camera goes under over a certain level of Y the text starts spinning around it’s Z-axis.
    is this a common problem?
    is there a way to orient the text towards the camery on its Z-axis while X and Y allways stay parallel to the edges of the camera window even when my camera turns around its Z axis?
    chears
    sebastian
    seniormartinez
    Sebastian Martinez replied 18 years, 10 months ago 1 Member · 1 Reply
  • Sebastian Martinez
    November 5, 2007 at 1:07 pm
    hi,
    just after i posted the previous one i kind of discovered the solution for the problem: i orienteted a null to my camera and linked my text layer to the null’s orientation data via the code posted here by Dan Ebberts:
    https://forums.creativecow.net/readpost/227/42
    thanks Dan! that solved a problem i was faced with since weeks!
    It now works like a swiss made – except the fact that the Z of the text layer doesn’t point directy to the cam but a bit right or left (parallel to the orientation of the null). might there be even a diferent way to overcome this?
    chears
    sebastian
    seniormartinez
