Activity Forums Adobe After Effects Layer size and render speed
  • Layer size and render speed
    Posted by Steve Morris on June 23, 2007 at 3:13 am
    I know if I use Grow Bounds, the render time goes way up.
    My question is:
    Are the render times affected the same if I use Grow bounds to increase the apparent layer size? Or, is it better to just start with a larger layer made in Photoshop and leave a lot of empty space around the object to allow for certain effects?
    Another related question.
    Does the size of a blank solid with no effects change the render times? I tried using Motion Tile to increase the size of the solid. I thought it would reduce render time. It did not seem to help.
    Steve Roberts replied 19 years, 3 months ago 2 Members · 1 Reply
  • Steve Roberts
    June 23, 2007 at 4:36 am
    These are questions that can best be answered by making comparison tests yourself. 🙂
