Activity Forums Adobe After Effects Layer Problem
  • Layer Problem
    Posted by Alex Smith on August 30, 2005 at 8:52 pm
    I am animating two layers in a composition, Layer 1 is in the foreground and Layer 2 is in the background. As Layer 2 moves past Layer 1, it jumps in front of Layer 1 and then several frames later it jumps back. Is this a glitch in my software or is there a way I can fix it?
    Alex Smith replied 21 years ago 3 Members · 3 Replies
  • Lazlo Hollyfeld
    August 30, 2005 at 9:06 pm
    There maybe a mask appearing at a certain point in layer 1. Check out your alpha channel for layer 1. It could very well be a software / hardware rendering issue. Try taking OpenGL off. It’s a little button on the comp window. Hope that helps!
    Arie
  • Steve Roberts
    August 30, 2005 at 10:09 pm
    You might get this problem if the two layers are 3D and they share the same Z-position. If so, try moving the background layer back 1 pixel in the Z direction.
    Steve
  • Alex Smith
    August 31, 2005 at 8:26 pm
    Thanks for the help. I changed the z-position of one of the layers and now it works.
    –Alex
