Activity Forums Zaxwerks layer positioning
  • layer positioning
    Posted by Mike Rother on May 28, 2008 at 10:10 pm
    heres my problem:
    I have a block of text consisting of 12 lines.
    When I apply Invig to the text block using a comp camera everythings great and all the planes are flush.
    then I duplicate the Invig layer 12 times
    delete one line of text at a time so I end up with 12 separate invig layers making up the text block.
    now the 12 separate layers arent flush anymore. They look like they all have diff Z positions?
    does deleting a line at a time change some kind of hierarchy in positioning?
    hopefully this makes sense
    thanks in advance
    Jerry Witt replied 18 years, 3 months ago 3 Members · 5 Replies
  • Jon Okerstrom
    May 29, 2008 at 4:22 am
    Hi Mike,
    Deleting lines of text would cause the positioning to shift from layer to layer. One solution: replicate the text blocks exactly and make the lines you don’t want to see in each layer invisible – without deleting the objects. I’m thinking this would keep all of your text in proper registration.
    Jon
  • Mike Rother
    May 29, 2008 at 5:35 pm
    Hi Jon–
    I tried duplicating all the layers and then making all lines except the one I need invisible. The layers still stack up incorrectly.
    any other thoughts?
    thanks again
  • Jon Okerstrom
    May 30, 2008 at 12:37 am
    Are they in exactly the same position in Z space?
    Jon
  • Mike Rother
    May 30, 2008 at 7:28 pm
    yes. When the “text wall” is one unit of 12 lines, all lines are in the same Z space.
    Studying the problem further, it seems that when I break up the wall into separate lines Invig treats each line as its own object. For instance layer 1 doesnt know there is a layer 2, so the bottom extrusion of layer 1 draws on top of layer 2.
    If I didnt have 12 lines of text I could make each layer of the single text wall into a set and animate the set, but Invig only has 8 sets…
    make sense?
    thanks again
  • Jerry Witt
    June 16, 2008 at 9:02 pm
    What if you didn’t delete the lines, but replaced them with a carriage return?
