Activity Forums Adobe After Effects layer order getting under my skin
  • layer order getting under my skin
    Posted by Al on July 10, 2007 at 9:50 am
    i’m having issues with a bunch of layers in z space.
    AE will not register their true position in z space in so much as;
    layer A is at the top of the timeline.
    layer B is under layer A on the timeline.
    BUT layer B is further back in z space than layer A.
    Why does AE still show layer A being infront of layer B?? I realise that on my actual timeline layer A is above layer B – but surely me moving my layers in z space is the key factor here – NOT the layer order.
    Am i alone in my madness here?
    Aaron Edwards replied 17 years, 3 months ago 3 Members · 2 Replies
  • Darby Edelen
    July 10, 2007 at 4:24 pm
    [muiisal] “BUT layer B is further back in z space than layer A.”
    If layer B is farther back in Z space then layer A should appear on top of it. This is normal. However, since it sounds like you’re upset about something I assume you got your layer A’s and B’s crossed in this statement? =)
    Are you using any track mattes in your project? Any adjustment layers? Viewing from the ‘Active Camera’?
    If you include a screen grab of AE, focusing on the timeline with the shy switch off and the transform properties twirled down for these two layers then we should be able to get to the bottom of this!
    Darby Edelen
    DVD Menu Artist
    Left Coast Digital
    Aptos, CA
  • Aaron Edwards
    May 22, 2009 at 4:30 pm
    You prob have a layer style (ie drop shadow) delete that and you should by fine.
    best
    aaron
